Page 2 of 3
Re: 06 Jag schrader valve replacement
Posted: Thu Mar 25, 2021 9:33 pm
Is the port adapter (the part into which the Schrader valve screws) removable from the liquid line? If so, you might be able to locate another adapter with the same thread that accepts a more readily available Schrader valve.
Posted: Fri Mar 26, 2021 5:43 am
by mikeh85
JohnHere wrote: Thu Mar 25, 2021 9:33 pm
Sadly, no. They are part of a line set that runs between the evap and compressor/condenser. And although the complete line set is available for around $150, it is one of those parts that was put on before the rest of the car was built.
I'll check with Century Tool, but really seems like I should just get the Jag valve. Did not realize this little part was going to be such a headache. I thought a schrader is a schrader... clearly not since I'm doing the job a 2nd time.
Posted: Fri Mar 26, 2021 9:58 am
After looking into this in more detail, the aftermarket Schrader valve that you used, although different looking from the original part, is supposed to be the correct replacement. It's certainly possible that the "new" one was defective from the factory, or maybe the factory just forgot to put in the nylon/rubber seat seal that we expected to see, resulting in the metal-to-metal contact area that you noticed. You could try ordering another aftermarket kit from Santech, or bite the bullet and go with the OEM part and a new cap to ensure it's sealed up nice and tight.
Posted: Fri Mar 26, 2021 11:19 am
by mikeh85
JohnHere wrote: Fri Mar 26, 2021 9:58 am
Hmm... didn't know these were made by Santech, that is a clue that helps a lot. Googling that, I found there's a Santech MT0301 valve which looks like the OE except it's specified for Volvo. Can't quite tell if the threads are the same, but from photos it looks identical.
The one I used does not appear to ever have had a seal inside it. I guess now the question is do I throw a few bucks at ordering these Santech 301s and see how they compare. Are these generally a trusted brand/construction? I see they are shipping from China. Or I could get a OE Volvo 6849305 for $9. Ford owned both Jag and Volvo in those years, bet dollars to donuts they shared the same supplier.
Posted: Fri Mar 26, 2021 3:02 pm
The Santech brand is well known in the trade, so I wouldn't hesitate ordering from them. The ones you turned up from Santech and Volvo seem to be a close match, if not identical, and probably produced in the same factory in China. Chances are either one would fit. Your call.
Posted: Fri Mar 26, 2021 4:11 pm
I looked at those yesterday. Not sure if they are the same, so did not mention them. Good chance they are. Local NAPA should have them.
Posted: Sat Mar 27, 2021 7:11 am
To me, it's just so weird that low-volume vehicle manufacturer Jaguar would use such a specialty schraeder valve in the first place !!!
Posted: Mon Mar 29, 2021 9:06 am
by mikeh85
Thank you all for the replies--I'll order some of the Santech and see how they compare to the original. If my local NAPA has them in stock I'll bring the OE to compare. Will post back when I find out more.
Ha, nothing on Jaguar surprises me anymore. Most of the engine and vehicle sensors are standard Fomoco or Bosch parts, electrical connectors are from Toyota, so you can usually cross reference those to the OE supplier. But the AC system seems to be an odd conglomeration of things nobody else uses. When I replaced the condenser I could not find o-rings that matched. I have 2 ktis of AC o-rings and nothing was the correct CS or ID. Ended up having to pay $6/ea from the dealer for those.
Posted: Tue Apr 13, 2021 8:27 am
by mikeh85
Finally received the Volvo schrader core, and it is identical to the Jag core. After looking at pictures of the Santech core for the Volvo I noticed the metal looked different than OE, so for $9 I got this one. I guess i should replace both if one is leaking, no point going through this again.
One thing I was unable to find is a new service cap. Jag does not even show it on the parts breakdown. Looking at the aftermarket it looks like there's all kinds of cheap plastic caps on eBay and Amazon. Is there a brand I should look at to get a good quality replacement?
Posted: Tue Apr 13, 2021 7:36 pm
It is possible that the only way you are gonna get a cap that fits is to get an assortment.
Tim from ACKits.com has them under SERVICE PORT CAPS ASSORTMENT.
There are many sizes such as 13mm & 13.5mm & 14mm & 16mm &17 & 17.5mm
We have used our kit a lot to replace various missing caps on customer cars. If ever there were an area of automotive engineering screaming for standardization...
