Page 2 of 2
Re: 99 Maxima poor cooling
Posted: Sun Jul 12, 2020 6:53 pm
by robmaxfli
To verify that there is a blend door type issue , you could pull off the 2 heater hoses from the heater core, buy a connector/bridge to join those 2 hoses together. I just did this and it proved to be a blend door issue. This will take the heat out of the heater core so you can get a heat-free reading out of the vents.
Posted: Mon Jul 13, 2020 5:59 am
Al9 wrote:Or you could just turn AC on as soon as you start a cold engine, while the coolant is still cool. If you get anything better than 70F vent - and ideally this has to happen in a few secs with a brand new compressor and a properly charged and oiled system, more so when in the shade - reheating is your problem.
This.
Posted: Mon Jul 13, 2020 9:12 am
by cmilot6329
Definitely not getting any colder with a cold engine so don't think it is an issue with the blend door. AI9, when you say reheating is your problem what does that mean exactly?
Thanks!
Re: 99 Maxima poor cooling *SOLVED*
Posted: Mon Jul 20, 2020 11:33 pm
by cmilot6329
**SOLVED**
Updated OP
Posted: Tue Jul 21, 2020 6:21 pm
by cmilot6329
Awesome thx for the additional info! Probably won't have this car too much longer so not sure the extent I wanna continue to mess with this. For now I'm happy just having some cool air again.
