Re: Minimum compressor RPM
Posted: Sat Jul 18, 2020 6:58 am
This is how I have the turnbuckle attached. I set the belt tension first. Then preloaded the turnbuckle slightly.
After purchasing the Alan Grove bracket I noticed another bracket I could have bought that has a turnbuckle included but attaches to slightly different points on the head.
I read that Sanden recommends no more than .006" ear deflection due to breakage and leaks. I set up the spacers you see on top with no slack between the ears before tightening the bolt. I had to shim the bottom mount as well with a steel shim that was about .020" to get no play as well when I first installed the compressor.
