Page 2 of 2
Re: R12 system on 79 Trans Am
Posted: Sat Mar 21, 2020 5:06 am
by warrenseale
The inlet and outlet lines of the evaporator are cool, not cold as they normally should be. The hot/cold damper door is functioning properly.
Posted: Sat Mar 21, 2020 7:09 am
Unless I'm missing something. Full Refrigerant, cool inlet and outlet lines, hardly any variation from static pressure. Compressor spinning.
Seems to be a bad compressor.
Posted: Sun Mar 22, 2020 9:38 am
by warrenseale
Well I opened up the system and pulled the orifice tube and found a couple pieces of rubber that looks like o ring material but which is not from the pipes/hoses. More concerning is that the screen was loaded with metal particles. Prior to the rebuild when I pulled the original 40 year old orifice tube, there was no debris plus I flushed and blew out the system prior to installing the compressor. Now I have to deal with the rebuilder
Posted: Mon Mar 23, 2020 11:04 am
Offhand, I don't know what the specs are for your car. But if the rebuilt compressor was empty of oil when you received it, did you add the correct amount and type of oil?
Posted: Tue Mar 24, 2020 10:59 am
by warrenseale
The rebuilder fills it with 11 oz of ester oil. This is the full oil capacity of the system. Anyway, they are having me ship it back to them.
Posted: Fri Mar 27, 2020 12:09 pm
by warrenseale
Well the rebuilder received and inspected the compressor and found an extra o ring inside it. They removed it and said that otherwise the internals look OK. They said the extra o ring would have caused the symptoms I experienced. We'll see! At least they turned it around in one day and paid for shipping to and from. The final testing shows it is working normally. I asked if they tested it the first time when the extra o ring was in place. They said that either they missed that step
or it checked out OK at the time.
Posted: Sat Mar 28, 2020 8:56 am
I wonder where the metal particles came from, though. Usually, that means something inside the compressor is disintegrating, as mentioned earlier.
Posted: Sun Mar 29, 2020 9:24 am
by warrenseale
JohnHere wrote:I wonder where the metal particles came from, though. Usually, that means something inside the compressor is disintegrating, as mentioned earlier.
Most likely from the compressor prior to the rebuild. Some particles could have been sitting in the bottom evaporator tank even after the flush.
Posted: Sun Mar 29, 2020 9:25 am
by warrenseale
Ahhh! They positioned the clutch connection at 10 o clock instead of 2 o clock! There is no way the wire harness can reach it.
Posted: Sun Mar 29, 2020 11:13 am
Ensure that you clean out any remaining metal particles. Metallic debris in the system that makes it back to the compressor will quickly ruin it.
