Re: AC Compressor not kicking on when trying to recharge system
Posted: Mon Oct 21, 2019 7:58 am
Thought I'd mention that Tim at AC Kits, this site's sponsor, has two styles of side can taps in stock. One can handle three types of cans: R-134a, R-12, and oil. The other one handles only R-134a cans. Each is priced the same.
I don't recall your mentioning the vehicle's make model, and year. But if it holds 24 ounces, that would equate to about two cans of pure R-134a charged into an original R-134a vehicle. A better way is to weigh-in a precise charge. Newer vehicles hold relatively little refrigerant and are very charge-sensitive. System performance can be affected if the charge amount is off by even an ounce or two. Something to keep in mind.
Regardless, it does seem as though your compressor is weak if you have a full charge in it now based on the pressures you reported. At 75 degrees ambient, engine at 1,800 RPM, doors open, and blower on high, I would expect to see the high side at around 190 PSI. Conversely, the low side seems high, so I'm not surprised that you're seeing vent temps in the uncomfortable 50-plus degree range--not acceptable for Phoenix or for the humid South, where I am.
A couple of additional questions: When you changed the TXV, did you find any type of debris or desiccant beads clogging it? Also, did you replace the receiver/dryer at the same time?
