Page 2 of 2
Re: Pressure Checks 2000 Excursion
Posted: Fri Sep 27, 2019 4:10 pm
by hbabler
I will test the engine fan and if it checks okay do a full load test like y’all describe and post the results back here.
I have only had it about 6 months. It had a leaky manifold hose assembly and a dirty evaporator so when I changed those I elected to change the compressor and dryer as well as I figured that it couldn’t hurt anything.
Posted: Sat Sep 28, 2019 12:36 pm
Fan clutches wear out. And the 9 blade plastic fan is a big load on that clutch.
I would use a Motorcraft YB3157 Clutch.
I would also inspect the plastic fan blade carefully. I had one come apart after a new clutch was installed.
Motorcraft YA225 is the fan blade.
Aftermarket clutches only last a year on the F450's around here.
Posted: Sun Oct 06, 2019 2:58 pm
by hbabler
Here’s an update.
The fan clutch seems to be doing okay. It won’t move more than an inch or two when cold. I can hear it engage when the truck gets hot.
Pressure for today.
96 degree ambient. (Not sunny though so the heat load wasn’t as bad as normal)
1900 rpm for 2 minutes, doors open front and rear on high recirculate.
High 285
Low 45
Vent 55
When I misted the condenser the pressures dropped quickly. (I may have applied too much water)
Do I need a condenser? I noticed I am getting a little heat bleed through when the AC off so I purchased a new heater shut off valve and I will swap that tomorrow.
Any other ideas as to what I can try next? Am I expecting too much out of this AC? Our 2008 suburban has a much colder AC both at idle and driving.
Also here are the idle pressures just in case.
Idle pressures:
High 215
Low 51
Vent 60
Posted: Sun Oct 06, 2019 3:14 pm
hbabler wrote:Here’s an update.
Test that fan clutch when its HOT. If it spins too freely, replace it. Because you stated that misting condenser caused the pressures to quickly drop.
Posted: Mon Oct 07, 2019 4:16 am
by hbabler
So I checked it this morning after driving to work and it’s not as tight as it is when it’s cold.
I can spin it about one blade in either direction. Do I need to replace it? It appears that everything is pointing that way.
Posted: Mon Oct 07, 2019 5:09 pm
285 psi @ 96f ambient says you are not getting good condenser performance. That test is a good analog for leaving work at 4pm after the truck sits in the sun all day. You will have the cabin fan on max with the throttle open - and low ground speed.
The fan clutch or the condenser (or both) need help. How does it cool on the road at 45 to 55 mph & 1900 rpm?
The water on the condenser shows you where the pressures can be.
I would inspect & clean the air path through the heat exchanger stack. Bugs & dirt can block airflow through the whole path, reducing airflow. Use a strong surfactant like Simple Green or Purple Power sprayed full strength in to the fins & allowed to soak for a few minutes on a cold vehicle. Flush with a garden hose nozzle - a power washer or other high pressure water source can bend fins, so stick with the hose.
A good fan clutch will wake the neighbors on a cold start. It will spool down in a few minutes. At 96f ambient, idling for 4 or 5 minutes at a light should lock it up - and make it howl leaving the light. We still have some 7.3's in service here in tow trucks and shuttle vans - I can hear one coming down the street anytime the ambient is over 90f. F450's just won't die.
Posted: Tue Oct 08, 2019 6:21 pm
by hbabler
Okay that makes sense. I am certain the fan clutch is weak. I’ll order one and clean the stack and try again.
It cools pretty well at 40-45 MPH. Somewhere in the upper 40’s.
Thanks for all the help!
