Page 2 of 2
Re: 2006 Saturn Vue cooling at idle
Posted: Sat Jul 20, 2019 8:58 am
The sensor is on the high side line someplace. AC Delco part number 1551343
Again, a Mitchell subscription can be a big help. You can screen shot the wiring diagrams & save them, that alone is worth the $20 charge
https://eautorepair.net/Marketing/Default.asp
Posted: Sun Jul 21, 2019 5:42 pm
by atikovi
What brand compressor?
Posted: Sun Jul 21, 2019 6:11 pm
by satvue
I've tried 2 remanufactured compressors and one labeled NEW, all same results. I put a new scroll valve in the initial compressor hoping that was the issue, no dice.
Posted: Sun Jul 21, 2019 6:12 pm
by satvue
bohica2xo wrote:The sensor is on the high side line someplace. AC Delco part number 1551343
I'll give the Mitchell subscription a shot, Thank You.
Posted: Wed Jul 24, 2019 4:53 pm
by satvue
Changed out the highside switch, no change. If I hold the throttle down at 1500rpm, temp immediately drops, I let off temp immediately goes back up. Any other ideas?
Posted: Wed Jul 24, 2019 5:17 pm
by atikovi
satvue wrote:If I hold the throttle down at 1500rpm, temp immediately drops, I let off temp immediately goes back up.
That's opposite of what you say in your title.
Posted: Wed Jul 24, 2019 7:13 pm
by satvue
atikovi wrote:satvue wrote:If I hold the throttle down at 1500rpm, temp immediately drops, I let off temp immediately goes back up.
Do you typically only read thread titles?
Re: 2006 Saturn Vue NOT cooling at idle
Posted: Wed Jul 24, 2019 7:18 pm
by satvue
My apologies for the misleading thread title. I don't see an option to change the title. I'll see if I can get a mod to adjust it.
Posted: Thu Jul 25, 2019 5:02 am
by atikovi
satvue wrote:atikovi wrote:satvue wrote:If I hold the throttle down at 1500rpm, temp immediately drops, I let off temp immediately goes back up.
No but the facts stated here are contradictory. Regardless, if there is normal cooling at above idle that drops to little or no cooling at idle speed, it points to a bad control valve in the compressor. Or at least it has on 3 of my last Vues in which I replaced the valve.
Posted: Thu Jul 25, 2019 7:37 am
by satvue
New control/scroll valve was the first thing I did, didnt help.
