The line getting into the condenser is hot (not warm but hot). The same line leaving the condenser is somehow cool.. Not cool but definitely colder than ambient.
Is this the way it supposed to be?
Condenser lines
Condenser lines
Re: Condenser lines
Depends on the vehicle- all GM trucks (front only systems) have their expansion device (OT) in condenser outlet- so yes, condenser line to evaporator will be cool---Most cars have their expansion devices at entrance to evaporator, so no, it should be warm---A condenser restriction can act as an expansion device as well-- causing a cool pipe...
Re: Condenser lines
it is a honda. expansion valve is in the evaporator. After the freon leaving the condenser , it goes to the dryer then the evaporator. If there is a restriction in the condenser. Could I still see liquid state freon on the sight-glass on top of the dryer ? I see liquid on the sight-glass. not even bubbles.GM Tech wrote:Depends on the vehicle- all GM trucks (front only systems) have their expansion device (OT) in condenser outlet- so yes, condenser line to evaporator will be cool---Most cars have their expansion devices at entrance to evaporator, so no, it should be warm---A condenser restriction can act as an expansion device as well-- causing a cool pipe...
Re: Condenser lines
Forums work better if people don't start new threads about the same problem they're having. Bump up your original thread with any new findings.
Re: Condenser lines
mk378 wrote:Forums work better if people don't start new threads about the same problem they're having. Bump up your original thread with any new findings.
I am sorry about this. I cut this discussion and pasted in the other question I asked which refers to the same car.
Please delete this post. I tried to do it myself, but I could not.
My apologies.
