bohica2xo wrote:Ah, the old defective return received from RockAuto. Because of the distributed wholesale nature of that operation, RTV items that don't get tagged get re-shipped to customers. Just the nature of the system when you run it with the lowest possible operating cost. They do usually make it right.
All of your testing points to an airflow issue. The fact that your clutch no longer locks up at idle is probably most of it, if not all of it. I am sure the defective unit cooled quite well...
The wet condenser test says the charge level is good. If it was badly overcharged with oil or refrigerant is would not drop that far.
There are still plenty of 7.3's on the road here in Las Vegas. Commercial vehicles that idle a lot - shuttle busses Tow Trucks etc. This time of year I can hear the fans on them a block away, well before I hear the diesel clatter. The ones with no fan noise all seem to have the windows down when it is 112f
Once you get a fresh fan clutch in it, try the full load test after the engine is at operating temperature.
yeah rockauto took the return with paid shipping and sent a replacement, no fuss. showed up last night so i'll get it swapped in when i have a minute over the next few days. apparently fan clutches are to be stored face down, so perhaps is related to how they stack them in the warehouse. i unboxed this one and put it face down and will leave in there for a few days. obviously not stored face down once installed though so not sure how much that could matter??
did review the illustrated parts catalog and poked my head around another 7.3 in my lot at work, all of the dams and shrouds seem to be in place.
thanks for your help and input - will let you know what i get.
