Properly check vacuum.
Re: Properly check vacuum.
Post by Dougflas »
are you using a set of gauges for R134a by any chance? I was under the impression you were using a set of standard gauges.
72gmc4x4
Post by 72gmc4x4 »
They are r134a gauges though I'm not sure if they are standard. Here is a link with some pictures of the set I had. You can see in the pictures the hose ends.
https://www.amazon.com/OEMTOOLS®-R134a- ... B01BW39AWW
What would you recommend I get? Something that is good but won't require breaking my piggy bank?
72gmc4x4
Post by 72gmc4x4 »
Btw, thank you for taking the time to help me out. I really appreciate it.
Post by Dougflas »
OK, forget everything I said about testing the hoses. BTW, that set appears to be made by TIFF and they are one of the better sets.
