2005 Grand Cherokee- siezed compressor: advice please!
Hi All,
I've got a 2005 Jeep Grand Cherokee 4.7 with a seized compressor. Just bought the car, so not much history. It was cooling fine when I bought it couple weeks ago, but the compressor was noisy, so I figured I'd be replacing it soon. It locked up a couple days ago, so I'll be replacing it sooner than I figured... There was no drama, just a squealing belt right after startup.
Looking for a little advice before I open it up.
1-I'll be ordering a new mopar compressor and accumulator. Should I plan on preemptively replacing anything else while I'm in there?
2-I found a reference list that says the system holds 24oz of PAG46. Should I plan to flush the system and add 24oz, or replace some portion that is in the compressor and accumulator?
I've got gauges, vac pump and an air compressor, but I've never flushed a system before. Is flushing a system pretty straightforward?
Walter
Walter
Re: 2005 Grand Cherokee- siezed compressor: advice please!
Next time: shut down the AC system immediately if it's noisy like that, it will just do more damage (like you found out).wamcneil wrote:Hi All, I've got a 2005 Jeep Grand Cherokee 4.7 with a seized compressor. Just bought the car, so not much history. It was cooling fine when I bought it couple weeks ago, but the compressor was noisy, so I figured I'd be replacing it soon.
Let the experts chime in, but think I'd replace or reverse-flush the condenser (if serpentine condenser) and replace the orifice tube.
That just sounds like a HECK of a lot of oil, check and re-check that !!!wamcneil wrote:I found a reference list that says the system holds 24oz of PAG46. Should I plan to flush the system and add 24oz, or replace some portion that is in the compressor and accumulator?
What exactly is seized?
The idler bearing? The pump itself?
It's apparently the compressor that's siezed. Idler spins fine once the clutch released.
Next time I'll know ... I figured on replacing it so wasn't too concerned. Hopefully it looks clean inside. I'll blow out the condenser and see if anything nasty comes out.!
Oh, sorry about the dumb question on the oil to add. I was looking at the refrigerant capacity... oil is 4.6 oz.
if the condenser is clean, should I try and flush the system and then add 4.6 oz, or skip the flush and add some quantity less than 4.6 oz?
I'm assuming the system was recharged with no added oil and the compressed failed from oil starvation
At minimum I'd reverse flush the condenser and high pressure lines with solvent then dry out with air. And change orifice tube.wamcneil wrote:if the condenser is clean, should I try and flush the system and then add 4.6 oz, or skip the flush and add some quantity less than 4.6 oz?
When you remove the seized compressor, drain/capture any oil and measure its volume; there might be zero. So I'd add the 4.6 oz.wamcneil wrote:Oh, sorry about the dumb question on the oil to add. I was looking at the refrigerant capacity... oil is 4.6 oz.
Thanks. That's what I'll plan on doing. Fingers crossed... like Mike Tyson said... "everyone has a plan untill they get punched in the mouth"
OK. Ordering parts from ACKits. Dryer, orifice tube and seal kit
I assume the orifice tube is replaceable, since ackits sells it, right? I can't find any instructions specific to a 2005 grand Cherokee. Is it just a matter of removing the liquid line from the firewall manifold block and pulling the orifice tube out of the firewall end of the hose?
Orifice tube is replaceable; make sure to orient it correctly.wamcneil wrote:I assume the orifice tube is replaceable, since ackits sells it, right? I can't find any instructions specific to a 2005 grand Cherokee. Is it just a matter of removing the liquid line from the firewall manifold block and pulling the orifice tube out of the firewall end of the hose?
Google on how to remove an orifice tube: it may come out readily, you may have to screw something in there and pull.
Thanks. Will do.
I'm reading that in a lot of cases a compressor failure can require replacement of the condenser because the passages are too small to effectively flush.
Is the 05 jeep condenser one of these modern condensers with tiny passages?
I figure if the orifice tube screen is clean, I'm probably good. But if it's full of trash then I might be looking at condenser replacement too?.
