A flat surface, some 180 grit wet-or-dri sandpaper, a little kerosene...
Take .016 off of that shim the old fashioned way.
Need to find the right part to replace my a/c clutch
Re: Need to find the right part to replace my a/c clutch
Really? That thought had crossed my mind but then I decided against it as being way too imprecise. My concern was that it could end up uneven, i.e. not a uniform thickness from one side to the other. I think I'll still look for one at the hardware store that is an exact match and about half the thickness. If that fails, out comes the sandpaper!
Lapping the thickness of a few sheets of paper off is not too hard.
Rotate the part often & flip it regularly. Lap in a figure 8 motion to equalize pressures.
Measure the part at a couple of spots. You can hold less than .001 with a little practice.
Sounds reasonably easy. And I could practice with any old steel washer I have laying around in my shop.
You can get these spacers and a high-end bike shop. They use them to space disk brakes on mountain bikes.
Wow, I never would've thought of that! Have a bike shop nearby, I'll check with them this week.
