every time i remove the service cap on the low side its tight like pressure builds up
it has green residue on it
and it appears to have a black ball for the inlet valve????? is this normal
the high side appears normal
low side service port
Re: low side service port
Those ball type "shraders" are known for this. The caps are the primary seal and the shraders are the secondary seals. I would not worry about it.
