R134a low side valve style
- msrichmond
I pulled the valve on the right out of my low-side port. The replacement in my FJC assortment is the one on the left. Is it compatible with what I took out?
- valves.jpg (147.28 KiB) Viewed 10920 times
Re: R134a low side valve style
The valve on the left uses an O-ring to seal the valve itself into the valve body.
It is not clear to me how the valve on the right accomplishes that task. I would try to get the correct valve
- msrichmond
I contacted FJC customer support.msrichmond wrote: Tue May 06, 2025 2:44 pm I pulled the valve on the right out of my low-side port. The replacement in my FJC assortment is the one on the left. Is it compatible with what I took out?
They said
So, the one on the left is the correct part which is 2676 and the one on the right that you received from Amazon is a 2677.
They (Amazon) have sent you the wrong part number.
I went back to our warehouse and physically looked at them and you have two different part numbers there.
Let me know your address and I will send you the correct parts.
I processed the refund through Amazon and they don't even want the incorrect one back.
Kudos to FJC customer support, all it took was an email.
Both parts are for low-side, 8mm. But the 2676 is for R134a and 2677 is for R1234yf.
