The previous owner converted the original R12 AC system to R134a, with new condenser, compressor, receiver-dryer and TXV. It worked REALLY well when I bought the car - by far the best-cooling R134a conversion I've seen - but after a few months of ownership, I noticed oil dripping from the condenser inlet fitting, and unsurprisingly, about a week later, the AC stopped working. I spoke to the previous owner and he confirmed the details of the R134a conversion and told me that it had never needed any top-ups since he converted it 2 years prior.
I'm a decently competent DIY mechanic and usually work on my own cars, but since it was going to need refrigerant recovery, I took it to a local shop. They refused to touch it, claiming that it still had R12 service ports. This was complete nonsense as I'd seen the ports with my own eyes and there were definitely R134a-style quick-disconnect adapters on them, but I assumed they were just making an excuse to not work on an old car with converted AC, so I left it at that. A while later I noticed that they had REMOVED the service port adapters, presumably venting the refrigerant and leaving the system open to atmosphere (since the R12 ports had their valve cores removed when the adapters were installed). Yikes! Not doing business with them again.
After that disaster, I made an appointment at an AC specialist, who replaced a torn o-ring on the condenser inlet fitting, recharged the system, and gave it a clean bill of health. However, within a year, it had leaked down again, with oil drips coming from the same fitting, and at this point there's no measurable pressure left in the system.
While the specialist shop was competent and easy to deal with, they were *not* cheap, and I can't afford to keep going back to them, especially not for time-consuming leak-hunting work. So this time since there's no refrigerant to recover, I've decided to DIY it. I've never worked on AC before, but I've read a few books on automotive AC and have a reasonable grasp on the theory. I've got myself a gauge set and vacuum pump, and plan on using straight R134a, not the nasty auto-parts-store stuff.
So where we're at right now is:
- No pressure in refrigerant circuit - gauges read 0.
- Visible oil deposits and lots of dye around condenser inlet fitting.
- UV light shows dye around pressure switch and service ports.
- Hoses and system components appear to be intact.
- System was left open in humid weather for ~2 weeks between visits to first and second shops.
- Examine condenser inlet fitting for sharp edges or damaged threads that could be damaging o-rings.
- Replace all o-rings in areas with signs of leakage.
- Replace receiver-dryer.
- Vacuum and recharge.
Additionally, while I gather that pressure-testing with air is generally a no-no due to it introducing moisture, if I'm going to be replacing the receiver-dryer anyway, would it hurt to pressure-test with (filtered, dried and oil-free) air *before* changing out the receiver-dryer? Buying a whole nitrogen cylinder would be a big expense for something that's hopefully a one-off job, and I figure that vacuuming it for a few hours on a hot day should deal with any moisture introduced by the air. Is there something I'm missing that would make this a bad idea? Seems like, given the system's recent history, it's already had plenty of moisture exposure and a bit more air shouldn't harm it any more than it already has been, but with how hard it is to find parts for this car, I don't want to end up wrecking something unnecessarily.
Thanks a bunch!
Richard
