2014 volt evap question
john,???
Post by john,??? »
so few questions, been so long since I checked on this board, all my old user name and password were probably for wiped in a forum update, had to register.
so I have a 14 volt, see dye in the evap drain. gotta pull the dash, blah. hate these new cars where it's a 2 day job to change the evap. but my question is what would be the best brand to put back in. normally I'd spend a little more and use the oem, but it seems from a quick Google search this is a pretty common fault with these cars. so maybe the oem isn't the best quality? I've got 90s cars with the original evap still in them working fine lol. gm things I guess.
anyways, I see oem and 4 seasons as options. anyone have any thoughts on which might last longer, I very much enjoy having this car and plan to keep it for as long as possible.
as for the electric compressor, I see they take poe oil. I have access to a Robin air ac machine but not one of the newer hybrid versions. I contacted them and asked if doing a hose flush before using it and adding oil by hand was enough to avoid issues. they basically said unofficially probably, but since it doesn't default to no oil injection like the hybrid specific models do, officially no it's not for use with both pag and poe. anything thought on that? it's almost do for a filter change anyways, I wouldn't mind doing a hose flush, replace filters, do another flush and add poe by hand. any thoughts? Just use it for recovery and charge.
and since I'm on the subject of electric ac compressors. I have 2 vehicles with electric ac and both ac work really well, that led me to wondering. I have a 90 firebird project car with the old leaky R4 comp. everything is still original and blew surprisingly cold for r134 swapped till the compressor leaked it out while parked on jack stands haha. they seem to make a new R4 not piston one that might not leak doesn't seem cool at idle well. they also sell brackets to install a sanden cycle type, but it's kinda ugly on top of the engine and my older stand alone ecm doesn't do great with cycling ac compressors with lumpy cams, no input for idle speed. years ago with the help of this board I put a v5 I had off a wrecked s10 on a 91 camaro I had at the time. it cooled really nicely, but my brackets were a hack job haha, was thinking about doing a v5 on this firebird too, but all these electric compressors got me wondering if it wouldn't be eaiser to just hide a electric off to the side somewhere out of the way or hidden, since I gotta make hoses anyways.
but that leads me to, does anyone know of any good ones? they all seem to be no name China stuff with no specs. I know my 2 cars use very high voltage ones. one is 300v and the other is 400v I believe, off the hybrid battery. is it even possible to make a 12v compressor that's any good? I don't mind putting a big alt on it. the common swap these days is the newer gm 220amp alt. they work amazing at idle speeds(more diodes or something). over 100amps at idle is no sweat from them.
sorry for the long post, just figured it would be better to not spam up the board.
Re: 2014 volt evap question
Well the general opinion of the consultants here is to avoid 4squeezins and R4 like the plague. And yes every thing comes from overseas in the usual unmarked think cardboard box that is already dented . Tim, the board sponsor here, has searched out the best available. So get your parts from www.ackits.com. You will find Tim to be very helpful
There is an interesting thread on here now about electric compressors
john,???
Post by john,??? »
yeah, I've purchased some stuff in the past from them. I was happy with it. it's been years thou, when I searched my email for my old log in it was 2020 haha. time flies.
it does seem like the R4 is just a waste of r134 at this point haha.
john,???
Post by john,??? »
no thought on what brand evaporator you'd trust the most?
Whatever Tim can get you will be a good choice, and his prices are very competitive. In fact surprisingly competitive. He knows what he is doing. I have never been disappointed
tbirdtbird wrote: Wed Aug 07, 2024 6:27 am Whatever Tim can get you will be a good choice, and his prices are very competitive. In fact surprisingly competitive. He knows what he is doing. I have never been disappointed
My 1988 Mazda truck runs an evaporator and a compressor from Tim ackits.com
2014 Volt needs an evap?
59-9911 Evaporator
john,???
Post by john,??? »
Tim wrote: Wed Aug 07, 2024 7:56 am 2014 Volt needs an evap?
yep, seems very common by Google searches and the car uses the ac to help cool the batteries so it's very picky about it's ac.
drain tube lit up like a Christmas tree under the light.
john,??? wrote: Wed Aug 07, 2024 8:02 am
Edited my post for the evap.
As already stated, 4squeezins products should be avoided
