6.0 PowerStroke DieselTim wrote: Sat Jul 20, 2024 6:24 pm Am I missing where the engine size is listed for these Excursions? Better yet, post the VIN.
https://www.ackits.com/index.php?route= ... 29476_6196
Thanks, look forward to what you find.Tim wrote: Sat Jul 20, 2024 7:48 pm Conflicting data from corporate. 6mm t&F v PFC. An old Motorcraft would have been the 6mm T&F multi-flow. I have to check on Monday.
The current condenser Im using is a described as "parallel flow micro-channel"Tim wrote: Sat Jul 20, 2024 7:48 pm Conflicting data from corporate. 6mm t&F v PFC. An old Motorcraft would have been the 6mm T&F multi-flow. I have to check on Monday.
Ok so don't shoot the AC hack........ For several years we used 1-800 radiators, as they were quick to deliver to the shop, fairly priced and frankly, we never had any issues. Delivery and getting the correct parts, or all the parts we order became an issue, we already used Oreilly's for the few things we did not use OEM parts on or other trusted brands, so we have been using the Murry line from Oreilly's for about 1 year now. The business model does not allow us to wait for days on parts most times.....so ordering from other non local suppliers is tough, on top of the additional wait when something gets lost in shipping, damaged, or wrong part picked and shipped.Tim wrote: Sun Jul 21, 2024 7:46 am I always used the parallel flow style over the 6mm T&F model. I usually don't ask this, but what brand of parts have you bought already?
Ok 10% is at least as a target point to check. 61.2 oz it is for the daily AC service.Tim wrote: Sun Jul 21, 2024 8:35 am The corporate group I do catalog work for is one supplier for 1-800. I was checking to see if we would overlap the parts you already have.
When we had our shop, I never needed to undercharge a system with a genuine version of the parallel flow condenser. But, even on the weekend, I reached out to one of the tech staff via text. He said on many of these Fords, they (do) suggest about a 10% reduced charge rate for some vehicles, many Fords. The only condenser we have in all locations is the parallel flow version.
I also noticed this during the forum cleanup. We lost the post on condenser designs with images and such.![]()
reclaimed? as in a refrigerant? Absolutely, evac refrigerant (and some oil), vacuum down and recharge is what Im doing.Tim wrote: Sun Jul 21, 2024 8:59 am Just keep in mind that less refrigerant means less oil carried for reliability. It will be a balancing act, so sometimes you need all the equipment to get the best performance out of a system, i.e., reclaimer.
