I bought this kit 20 years ago for finding oil leaks. It came with an AC leak detection setup that includes a special coupling hose, syringe and these instructions.
Are there any things I should worry about if I decide to use this?
Tracerline Leak Detection kit TP-1121
- msrichmond
- leak kit.jpg (24.59 KiB) Viewed 5318 times
- leak detection.jpg (233.74 KiB) Viewed 5318 times
Re: Tracerline Leak Detection kit TP-1121
I have used the UV dye system in the past, but have considered it to be cumbersome.
Have now used a sniffer for many years with very easy and good results.
The choice is yours
The choice is yours
Many vehicle manufactures these days add UV dye at time of manufacture. Myself, I add UV dye if a system doesn't have it.
On my last compressor install (2018, on my 2004 Frontier, R134a) I also installed new condenser and drier, and backflushed the high pressure line after its compressor seized at about 100K miles, and I added PAG oil that already contained UV dye.
