What adapter do I need between a drum of R1234yf and a R134a charging hose?
My manifold gauge set was made for R134A, but I bought R1234yf couplers to fit the car's R1234yf service ports. The problem is the yellow hose doesn't fit the left hand thread of the R1234yf drum of freon. What adapter do I need for that or must I buy a whole new hose?
Re: What adapter do I need between a drum of R1234yf and a R134a charging hose?
Is this what I need?
(Link removed.)
(Link removed.)
Reason: Sorry, links to outside businesses not allowed.
I found a box of adapters I forgot I had bought some time ago. These two have the correct threads. Any reason to use one over the other?
No
Ok, using the one on the left with the knurled body for easy changing.
