How much vacuum
- Mogman
Re: How much vacuum
OK, I did a little more reading, it does have a umHg, cool!
- andrew vanis
Re: How much vacuum
Which one are you using, I'm in the middle of choosing one so would like you consider it as an option.
Re: How much vacuum
This is the one I picked up, I have no idea how accurate it is, if it meets the specs listed it will do.
- andrew vanis
Re: How much vacuum
Thanks for that info, it is one of the one's I have on order, it is a diff "brand" but the same unit - physically and specs.
- andrew vanis
Re: How much vacuum
FWIW, the version of that I got had the highest outrageous reading in this list.
https://www.autoacforum.com/viewtopic.p ... 336#p28336
- andrew vanis
Re: How much vacuum
FWIW2 - turns out I got a second one, the second one also had the outrageous high reading compared to others. 0/2 on that one ....hope yours is reading better.andrew vanis wrote: ↑Mon Oct 23, 2023 7:17 pmFWIW, the version of that I got had the highest outrageous reading in this list.
