New Parts But Can't Pull a Good Vacuum
Re: New Parts But Can't Pull a Good Vacuum
My guess is that the ambient temperature was between 75 and 80 degrees. Still, I'd like to see the low side a bit lower than that. Keep an eye on it. If the evaporator ices up, it might be a little undercharged.
Will do. I'll report back periodically with how its holding up and pressure values.
