Thanks for all that info. I was out of town all last week so I have not been on here or looked at the truck again. While I was gone, the owner decided to change the cycling switch. He got one at Autozone and apparently for some reason it didn't fit correctly and somehow let some of the refrigerant out of the accumulator where the switch screws in. He eventually goes to the dealer and gets a Motorcraft cycling switch and a new harness connector because the new switch has an oblong shape where the connector plugs in. I guess he has lost enough refrigerant to where the AC doesn't cool at all now. I'm not sure what his plan is next. He hasn't asked me to recharge it again, probably because I did it for free including the refrigerant.JohnHere wrote: Mon Jul 18, 2022 7:46 am Adding to what has already been said:
The vacuum dropping slightly was a sign that air and moisture were still present in the system. Hopefully, you got them all out with the additional 20-minute evacuation.70monte wrote: Sat Jul 16, 2022 3:41 pm Well, the AC charge was evacuated, and I vacuumed the system down for 30 minutes and then let it sit for 30 minutes. The pressure decayed slightly so I vacuumed again for about 20 minutes and let it sit for about another 20 minutes and the pressure held. I recharged it with 45 ounces.
We're not concerned with idle-speed pressures because the compressor isn't doing very much at such a low RPM. But at 1,500 RPM and an ambient of 96°F, that's fairly normal operation, and the pressures look pretty good at this point. Earlier, though, they're fluctuating abnormally. The question is, why?70monte wrote: Sat Jul 16, 2022 3:41 pm I had him do this again a little later and the low side would drop to about 22 and the high side about 250 and then the cycling switch would kick the clutch off.
The cycling switch and/or the PCM are turning off the compressor so that the evaporator doesn't freeze up, blocking airflow.
The lines you mention being cold is good. The line from the condenser up to the OT being hot is also good. However, you shouldn't feel any cold air coming out around the line extending from the blower housing. I would seal-up that opening with a suitable caulking or foam.70monte wrote: Sat Jul 16, 2022 3:41 pm The lines coming out of the accumulator were cold and so was the line that was going into the heater box or whatever it is called that attaches to the firewall and houses the blower motor. I did notice that there was cold air coming out around that line which did have some foam around it but was missing some at the top. I don't think air should be coming out of there but I don't know. The other side of that line was hot after the connector, and I believe the orifice tube is located in that portion of the line.
Those vent temperatures are not acceptable for a properly operating system. The compressor on your truck doesn't have a control valve, either. It's possible that the cycling switch is going bad, but it seems to me that it's doing its job as intended.70monte wrote: Sat Jul 16, 2022 3:41 pm Vent temps at 1500-1800 rpms got down to 57 degrees and at idle were around 60-62 degrees out of the center vent with AC on max and high blower. We took the truck for a drive and vent temps stayed around 69-73 so I'm assuming the clutch is cycling on and off pretty rapidly. Not sure why it's cycling so much at higher rpms. Could the cycling switch be going bad?
At this point, with a truck that has about 230,000 miles on it, I would recover the charge, pull the OT, and examine it. If the OT screen is full of gunk and even some metal particles, that would indicate the compressor is on its last legs. In such a case, I would replace the compressor with a brand-new unit (not rebuilt), the condenser, OT (specs call for a red one), accumulator, and flush or replace the liquid line between the condenser and the evaporator depending on whether it has a muffler. If it has a muffler (I don't believe it does), you'll need to replace the line because mufflers can't be flushed.70monte wrote: Sat Jul 16, 2022 3:41 pm So basically we are back to square one. Not sure what the next step is.
Prior to me going out of town, I told him it was possible that his compressor is weak and needs to be replaced because of the mileage of the truck and he has no idea if it was ever replaced. He has already bought a replacement compressor and accumulator and plans to install them at some point. The location of the compressor is at the bottom of the engine and is not very accessible at all so it's not going to be a fun job.
I want to thank everyone for their input on this situation and I will keep you updated on what happens.
