My wife has been complaining about her air conditioner not working on the way home from work. It's about 95 degrees outside lately and she drives 45 minutes home.
I can see the compressor clutch spinning, and the fan spinning at the same time it does, it seems to turn on and off maybe every minute when idling. I assumed she needed more refrigerant and added a small can, it seemed to maybe work a little better for a day, but then went back to being warm. I noticed a big puddle building under where the evaporator is. I added UV dye thinking it was maybe a leak, but the dye isn't coming out anywhere, no dye in the big puddle under the evaporator.
So I got some gauges and let the car sit over night. When I took these readings the temp outside was around 80, humidity about 70%. The 'off all night' reading was when the car was off and had been sitting all night. The 'compressor on' reading was when the clutch/fan were spinning, 'compressor off' was when they weren't spinning.
Thank you so much for taking the time to read this, and any help or tips are greatly appreciated. I don't know anything about this stuff, but I'm leaning towards just being low on refrigerant still, or maybe a stuck expansion valve.
