Leak
Re: Leak
That is a nightmare
I'd be looking at a salvage yard,
or finding the male end somewhere and getting swagelok fittings
Re: Leak
I know, that's what I've been trying to say LOL.
Excellent idea!! Find one in a salvage yard and just cut it off in the straight part where it's crossing over the condenser and splice it in with a swagelok. I should have thought of that, fog brain set in apparently, lol.tbirdtbird wrote: Thu Jun 02, 2022 3:27 pm I'd be looking at a salvage yard, or finding the male end somewhere and getting swagelok fittings
Thanks tbirdtbird !!!
Re: Leak
You'd need aluminum SwageLok metric fittings, so likely would need to order those. My suggestion would be to remove the front end stuff and then remove the condenser, that's what I'd do. See Posts 27 and 28 here https://www.clubfrontier.org/threads/20 ... 842/page-2tnfarmboy wrote: Thu Jun 02, 2022 3:50 pmI know, that's what I've been trying to say LOL.
Re: Leak
No need to remove the condenser. The line is about 8.5mm OD. I'll stop by Fastenal tomorrow to see if they have the splice. The red line represents what will be replaced. I'll be sure the replacement line isn't stressed in the same place. I'll be chillin soon!Cusser wrote: Thu Jun 02, 2022 4:26 pm You'd need aluminum SwageLok metric fittings, so likely would need to order those. My suggestion would be to remove the front end stuff and then remove the condenser, that's what I'd do. See Posts 27 and 28 here https://www.clubfrontier.org/threads/20 ... 842/page-2
- Lsplice.jpg (192.03 KiB) Viewed 6276 times
Re: Leak
Re: Leak
Just in case anyone is interested, I wound up getting the new line and it was actually pretty easy to install. I did a quick test and it seems to be holding pressure, so it's evacuating now.
- NewLine3.jpg (206.67 KiB) Viewed 6162 times
Re: Leak
Thanks for the update and good luck!
