Newbie question, I have a second hand Yellow Jacket vacuum pump which seems to work well, I drained and refilled the oil but when I used it there was vapour coming from the breather on the top.
Is this normal, is there a problem with the pump or is it showing there was a lot of water in the system being vacuumed.
The car was my own classic which had an R134a conversion 8 years ago and as the a/c was gradually getting worse I decided to fit a new dryer and refill with the correct weight of gas. The system is now operating great but I just wanted to know what the vapour was.
Vacuum pump vapour
Re: Vacuum pump vapour
My guess is that the visible vapor was some mist from the vacuum pump oil.Jaz wrote: Thu Feb 24, 2022 1:45 am I drained and refilled the oil but when I used it there was vapour coming from the breather on the top.
My primary vacuum pump was given to me when the R&D of our sister company was moving to another state. I was told that the vacuum pump smoked, and I told them I wouldn't be using it inside. Anyway, hasn't smoked when I use it, and I've been happy with it even though it is somewhat heavy to carry.
Overfilled?
There is a sight glass with a mark.
Correct type of oil?
Vacuum pump oil is especially for vacuum pumps only
Google search your exact make/model and see what you come up with
Its a Yellow Jacket pump and I bought Yellow Jacket oil and drained the pump and filled to the line on the sight glass.
Then I would not worry about it.
