Cooling issues over time
bazzybtec
Re: Cooling issues over time
Post by bazzybtec »
Al9 wrote: How much does the engine coolant temp affect AC operation?
the temperature is sitting where it normally is and the issue seems to happen well after the engine reaches the operating temperature.
The air is pulled through the condenser first then the radiator.
bazzy - you stated that the compressor drive plate stops turning after a while. I suggest to concentrate on THAT.
Agree.
