Short Back Story.
1990 Mazda B2200 AC all parts took apart, cleaned and put back together, new drier and compressor and using Duracool.
Worked great, till my evaporator had a leak in it at the suction side connection.
When I say worked great, I mean 95F ambient and heat index of 114F and vent temps reaching 36-38F
It cycled beautifully. There is a thermo switch on the side of the evaporator case and its designed to cut the compressor off at 33.8F and I believe it did that just fine.
I have two of these trucks and they both work the same.
Now present day.
I had an extra evaporator and I cleaned it up and had it ready to go with all new Expansion Valve in place. I put in it, charged it up as I have done many times and all was working well ACCEPT it was not getting as cold, or it would, it would just take longer because of the thermoswitch, turning it off at 46F and back on at 55F (vent temps).
This was not what it had been doing, plus it was sort of stinking like a water funk.
So after many adjustments and things that claimed to take smell away, I decided to just order a NEW evaporator and try again.
Brand new evaporator in place, no stink, all parts in place and its doing the same thing.
Instead of cutting off at 38F vent temp, it consistently turning off at 48F.
I decided to see if it was the thermoswitch and used a wire to bypass it.
When its bypassed, it gets the vents down to 35F, of course because its freezing down there.
I can't understand why both of my (known good) ThermoSwitches are doing the exact same thing.
It is not hard to install and I have placed them in the exact spot where they go and its done it to me twice. Its like its 10 degrees off in both directions.
Any tips or ideas?
Should I order a new one that has an adjustable dial?
This is the current switch part number, its by Ranco
a10-7071-000
https://pasteboard.co/JrcrWWL.png
