oK, I welcome quiz questions. Which is the clutch gap, right Bo?bohica2xo wrote:Or you could address the most common failure first.
Crawling under there in about 5 minutes.......
With a second look at this again, I get it now. easy test. Back outside with the mosquitos......bohica2xo wrote:Yeah Cusser, nobody wants to believe it is the clutch gap. Lots of compressors replaced for lack of an adjustment.
The hot resistance of the coil is greater than cold. Less magnetizing force hot. Add in some slightly higher resistance connections in the circuit... Quits working when it is hot.
Adjust the gap back down to .015 / .020 and it will work again.
Take a mirror & flashlight with you. When it craps out hot, leave it running, park & look under the car. Is the front plate spinning?
Woahhh! This is such great news, Bo!! All of a sudden my job became so much easier! Thanks, Man!! (will report back)bohica2xo wrote:The plate will come off without touching the belt. The plate floats on the compressor shaft, the pulley rides on a double row idler bearing pressed on the case of the compressor.
On my 1998 Frontier, I left the belt on, and only removed the drive plate part of the AC clutch when I removed a shim to fix its slipping clutch.pippo wrote:Woahhh! This is such great news, Bo!! All of a sudden my job became so much easier! Thanks, Man!! (will report back)bohica2xo wrote:The plate will come off without touching the belt. The plate floats on the compressor shaft, the pulley rides on a double row idler bearing pressed on the case of the compressor.
Cusser wrote:For my 1988 Mazda truck's Sanden compressor, the Autozone loaner tool did not fit either, I made my own tool for this. details and picture are here http://www.mazdatrucking.com/forum/show ... eplacement
For my 1998 Frontier I screwed in three 5mm bolt to extract its drive plate.
To loosen the bolt in the center of a drive plate, I have also left the AC belt on and tight, and jumped the wire to the AC clutch to get it to engage and then looened the center bolt.
