Dgreen wrote:Well, I changed the bearing and still have a noise. Also tried a different hub plate. Only thing I haven’t tried is a different coil and pulley. I put a stethoscope on the compressor and it sounds good.
Is it possible that the coil is weak and letting the clutch to slip and causing it to make noise?
Are ALL of the mounting brackets tight and in place? Is the system overcharged?
