Add High Pressure Service Port
Locked
kconatymd
Post by kconatymd »
I am a DIY'r with a good understanding of mechanics including automotive AC. I have a '95 Saab with a rebuilt AC Compressor that has only a low pressure service port. Where the High Pressure port goes was never tapped out with the port fitted.
I like to put gauges on my cars to check pressures from time to time, but there is nowhere to put the high pressure gauge.
Is it possible to install a high pressure port on the closed system? Someone suggested a bullet piercing valve. Anyone heard of doing this on the High side hose?
Re: Add High Pressure Service Port
kconatymd wrote: Someone suggested a bullet piercing valve.
I personally would not do a piercing valve onto a good line.
Dougflas
Post by Dougflas »
Piercing valves leak. A crimped Tee in high side sounds much better.
Locked
