Liquid line inside suction line?
Jag987
Post by Jag987 »
2015 Kia Sportage
First, there are no problems with the system, I had the hood open checking the oil. It was dark when I took the picture so it is not the best, but the liquid line goes inside the suction line for about 15 inches then comes back out. I haven't ever seen this before. Is it using the cold refrigerant leaving the evap to further cool the liquid before it gets to the txv? Good idea if that is what it is and I'm sure it works great, just a little trippy.
ice-n-tropics
Re: Liquid line inside suction line?
Post by ice-n-tropics »
The suction line heat exchange increases the overall icentropic system efficiency which results in slightly less horsepower per ton of cooling and can reduce liquid refrigerant below ambient for colder louvers
Worked on a Rolls Royce with a larger SLHX made by ARA. Rolls was a salesman and Royce a engineer so called it a Royce.
hotrodac
